hi......................bin mal wieder ueber etwas gestolpert. Diese kleine Kasten fuer die Vrod sollte doch auch ganz nett fuer die XB funktionieren..............kann das bitte mal jemand ausprobieren
VRFI Fuel Injection Controller for 2002-2007 V-RodTM with Delphi® System
Simultaneously auto-tune fuel curves for front and rear cylinders under actual riding conditions with new WEGO IID dual channel wide-band oxygen sensor interface
· Fully programmable plug-in replacement for Delphi® controller
· Robust alpha-N (throttle position and RPM based) fuel control eliminates problems with long duration/high overlap camshafts
· Powerful Windows software for custom programming and data analysis
· Full support for J1850 data bus used for communications with turn signal/security module (TSM/TSSM) and instrument cluster
· Data logging and diagnostics
· Billet aluminum housing with black anodized finish
· Easy plug-in installation
· All outputs protected against short circuits
· Supports all sensors including theft/security module
Q
